site to site VPN via ASA5540 question
Nov 8th, 2007
here is the basic info:
access-list public-2 extended permit ip host 163.148.20.105 101.161.0.0 255.255.0.0
global (Outside) 3 112.129.231.142
nat (Inside) 3 access-list public-2
crypto map Outside-map 10 match address Outside_20_cryptomap
crypto map Outside-map 10 set peer 163.148.20.105
crypto map Outside-map 10 set transform-set ESP-3DES-SHA
crypto map Outside-map interface Outside
crypto isakmp enable Outside
crypto isakmp policy 15
authentication pre-share
encryption 3des
hash sha
group 1
lifetime 28800
tunnel-group 163.148.20.98 type ipsec-l2l
tunnel-group 163.148.20.98 ipsec-attributes
pre-shared-key *
tunnel-group 163.148.20.105 type ipsec-l2l
tunnel-group 163.148.20.105 ipsec-attributes
pre-shared-key *
the other end does not see any data.
the other VPN box is 163.148.20.98
But we are trying to tunnel to 163.148.20.105 .
The outside interface is 112.129.230.13
Can you see any problem with the config?
thult Tue, 11/13/2007 - 01:56
Please explain the following:
"the other VPN box is 163.148.20.98
But we are trying to tunnel to 163.148.20.105"
What are the crypto endpoint and what address(es) do you want to include in the tunnel?
Do the other side use NAT/PAT to the .105 address?
Please show how you configured the "Outside_20_cryptomap" access-list.
