QOS grabbing those return packets
Nov 8th, 2007
Hi Guys,
I have a QOS question. Im trying to QOS return packets with random port numbers.
I'm doing basic outgoing dynamic NAT overloading to an outside address. (DSL)
I'm also doing some static NAT to redirect connections to from the outside address to my web server.
I have a QOS policy on the outgoing DSL interface to classify the packets into one of three queues. (high, medium, low speed with different shaping / priorities on each. The QOS packet matching is handled by mostly by nbar
One of the main packets I prioritize is RDP (MS Remote Desktop).
I use the custom NBAR line "ip nbar custom remote_desktop dest tcp 3389"
This works great.. every time I make an RDP connection from my local lan to somewhere on the internet the packets get correctly classified and all is good.
The problem begins when I RDP INTO my network from the internet.
The return packets are not being QOS'd
Here's the packet flow
* The packet with TCP 3389 dest hits my router from the internet dialer interface.
* The router does not care about QOS in any way at this point as I only have outgoing QOS enabled.
* The packet is natted to the internal server
* The server turns around and replies to the packet.... but... as with most TCP sessions, the reply uses random port numbers to respond.
* The reply packet reaches the router and the router places it into the default QOS group as the port does not match 3389
So does anyone have any idea how I can QOS the return packets?
Here's a config snippit (using an 1800)
class-map match-any qos-high
match protocol citrix
match protocol ssh
match protocol dns
match protocol telnet
match protocol snmp
match protocol dhcp
match protocol remote_desktop
class-map match-any qos-low
match protocol smtp
match protocol ftp
match protocol exchange
match protocol printer
match protocol nntp
match protocol secure-ftp
match protocol rcmd
class-map match-any qos-limit
match access-group qos-limit
policy-map qos-policy-internet
class qos-low
(do lots of things in here)
class qos-high
class qos-limit
class class-default
interface VLAN1
description Local LAN
ip address 192.168.0.254 255.255.255.0
ip nat inside
interface Dialer1
description Internet Connection
ip nat outside
ip inspect insp-fw-in in
ip inspect insp-fw-out out
service-policy output qos-policy-internet
ip nat inside source route-map NAT-MAP interface Dialer1 overload
ip nat inside source static tcp 192.168.0.123 3389 interface Dialer1 3389
ip access-list extended nat-outbound
remark NAT ACL
remark Permitted addresses to NAT
permit ip 192.168.0.0 0.0.0.255 any
remark External IP Address does not need natting (dont log its attempts)
deny ip host <outside IP> any
remark Deny All and log all other traffic trying to NAT
deny ip any any log
route-map NAT-MAP permit 1
match ip address nat-outbound
I can think of a few ways to perform this QOS including using reflexive access lists or tag the packets on the windows server but that all seems hard. There must be an easy way to do this.
Any ideas would be appreciated.
Ben
Kevin Dorrell Fri, 11/09/2007 - 05:30
  • Green, 3000 points or more
Ben,
The reply packets will be destined to a ramdom port because the original connection came from a random port. But what about their source address - won't that be TCP 3389? So couldn't you match the TCP source port with an extended access list?
ip access-list fromRTD
 permit tcp any eq 3389 any
Kevin Dorrell
Luxembourg
brom Fri, 11/09/2007 - 06:09
Kevin,
I had a look at that. It all seems to depend on the protocol being used. Some services use a static source port but most come from a random.
Unfortunately RDP seems to have a random port for both source and dest.
Ben
Kevin Dorrell Fri, 11/09/2007 - 06:19
In that case, it will be necessary to do some deeper protocol inspection, rather like is done for passive FTP. I suppose there isn't a pre-defined nbar definition for RDT?
Kevin Dorrell
Luxembourg
