Additional bgp route
Nov 8th, 2007
Dear all,
I am doing some bgp lab practise, once i finished the bgp configuaration on one router, observe there is one additional bgp route appear in the routing table. Could you give some idea why that happened? Thank you.
Vail#sh ip ro
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
B 192.168.200.0/24 [20/2195456] via 192.168.1.225, 00:08:46
192.168.255.0/32 is subnetted, 1 subnets
C 192.168.255.254 is directly connected, Loopback0
192.168.1.0/24 is variably subnetted, 4 subnets, 2 masks
B 192.168.1.0/24 [20/2169856] via 192.168.1.225, 00:08:46
C 192.168.1.224/30 is directly connected, Serial1/1.2 <<<<<(Why have this route)
B 192.168.1.216/30 [20/0] via 192.168.1.225, 00:08:46
C 192.168.1.220/30 is directly connected, Serial1/1.1
B 192.168.100.0/24 [20/0] via 192.168.1.225, 00:08:46
Vail#
Vail#sh ip int brief
Serial1/0 unassigned YES TFTP up down
Serial1/0.1 unassigned YES NVRAM up down
Serial1/0.2 unassigned YES NVRAM deleted down
Serial1/1 unassigned YES TFTP up up
Serial1/1.1 192.168.1.221 YES manual up up
Serial1/1.2 192.168.1.226 YES manual up up <<<<<<<<<<<<<<<<
Serial1/2 unassigned YES NVRAM administratively down down
Serial1/3 unassigned YES NVRAM administratively down down
Loopback0 192.168.255.254 YES manual up up
Vail#
Vail#sh ip b
BGP table version is 7, local router ID is 192.168.255.254
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 192.168.1.0 192.168.1.225 2169856 0 200 ?
*> 192.168.1.216/30 192.168.1.225 0 0 200 ?
r> 192.168.1.224/30 192.168.1.225 0 0 200 ? <<<<<<<<<<<<<
*> 192.168.100.0 192.168.1.225 0 0 200 ?
*> 192.168.200.0 192.168.1.225 2195456 0 200 ?
Vail#
Vail#sh run int s1/1.2
Building configuration...
Current configuration : 121 bytes
interface Serial1/1.2 point-to-point
ip address 192.168.1.226 255.255.255.252
frame-relay interface-dlci 311
end
Vail#
Vail#sh ip b s
BGP router identifier 192.168.255.254, local AS number 100
BGP table version is 7, main routing table version 7
5 network entries using 585 bytes of memory
5 path entries using 260 bytes of memory
4/3 BGP path/bestpath attribute entries using 496 bytes of memory
1 BGP AS-PATH entries using 24 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 1365 total bytes of memory
BGP activity 11/6 prefixes, 11/6 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
192.168.1.222 4 100 42 50 7 0 0 00:10:05 0
192.168.1.225 4 200 90 82 7 0 0 00:10:05 5 <<<<<<<<<<<<<<<<<<
Vail#
Kevin Dorrell Fri, 11/09/2007 - 00:31
  • Green, 3000 points or more
Does your EBGP neighbor (192.168.1.225) have a statement like network 192.168.1.224 mask 255.255.255.252? 'Cos that is where it is coming from to get into the BGP table. We need to see the configuration of the AS 200 neighbor.
However, it is not the BGP route that is getting into your forwarding table. That is getting overwritten with the directly connected route at AD=0.
Kevin Dorrell
Luxembourg
