UCCX 5 HA - Add to cluster Error
Nov 9th, 2007
HI,
I have 2 servers where I have to install UCCX 5 HA
So I installed:
1) ServerNode1(WinOS,CRS,SQLServer), when AppaAdmin started, I selected First Node, loaded the license file, activated all components and Publisher Datastores.
1) ServerNode2(WinOS,CRS,SQLServer), when AppaAdmin started, I selected "Add to Cluster" and inserted requested information but an error appears:
"Add CLuster is failed because of ClusterException TIMEOUT ERROR while waiting response from Bootstrap Manager"
What is the problem?
Can you help me?
Thanks.
Davide Fiumi Fri, 11/09/2007 - 01:02
I solved the problem.
I have to insert windows admin and no appadmin user.
Is it correct?
smaruvada Fri, 12/07/2007 - 08:17
When you add a node to the cluster, you need to enter the crsadmin a/c that you crated for node1 and its password. Reason being, once you activate node1, Administrator/ciscocisco a/c is disabled. Same is true for node2 but you don't have to create another crsadmin a/c in CM. HTH
bminetwork Sun, 09/06/2009 - 06:26
I am facing simillar issue while adding second node to the cluster, the error is:
" Add to cluster is failed because of ClusterException SYNCH_ERROR Error while waiting response from Bootstrap Manager.
I am using the admin password which I created in Node 1.
Could you please help me on this?
Ali Isa
cogden Mon, 10/19/2009 - 12:36
  • Bronze, 100 points or more
Did you resolve this issue?
I get it when trying to add a 2nd node to the cluster, and I know I using the correct CCX Administrator user credentials.
Chris
Steven Griffin Wed, 10/21/2009 - 11:34
  • Silver, 250 points or more
This can also happen if you used a broken mirror, Ghost, or some other cloning software to create the Telephony OS. Each OS must be installed separately for HA setup properly.
