Cisco 1841 ADSL drops for a minute, can I debug?
Nov 9th, 2007
Hi, I have a Cisco 1841 ADSL in VPN mode, every now and then it will drop for a minute and come back. This can happen only once a day. The ADSL line provider can't see that the line is the problem, however is there some sort of debug I can run for a day or too to see what is happening?
Paolo Bevilacqua Fri, 11/09/2007 - 01:46
You likely need to upgrade DSL firmware.
You can access the latest at
The one you want is 3.0.X, and there is a doc file that explain the installation procedure in detail.
Please remember to rate useful posts with the scrollbox below!
whiteford Fri, 11/09/2007 - 02:28
So it is:
Sh Dsl int:
SW Version: 3.8131
FW Version: 0x1A04
Worth an upgrade? If so I would have to try this over the internet and not console, high risk I guess.
Are there not debug commands to try as well?
whiteford Fri, 11/09/2007 - 04:23
I don't understand what you mean, It just came with an ADSL card from our supplier. Can I run a command for you?
Paolo Bevilacqua Fri, 11/09/2007 - 05:23
You have the older model WIC-1ADSL instead of the current HWIC-1ADSL that would accept firmware upgrade and is the recommended model for 1800 routers.
For WIC-1ADSL, I'm not aware of any possibility of upgrading firmware, per document:
You can enable the "dsl training logs", but I doubt it would bring to any improvement.
whiteford Fri, 11/09/2007 - 06:21
Thanks, it's only 3 months old too :(
Any newer ones I'll make sure I get HWIC. As I said it only drops for a minute and not too often.
