Unable to establish ISDN BRI.
Answered Question
Nov 9th, 2007
Guys,
I have a 2651 with VIC 2B-S/T TE with 1 X BRI ISDN populated.
I am unable to estable layer 2.
Following message.
Layer 2 Status:
TEI = 255, Ces = 1, SAPI = 0, State = ESTABLISH_AWAITING_TEI
Please see the router config:
SHOW RUN
Building configuration...
Current configuration : 1708 bytes
version 12.4
hostname AUC_GATEWAY
boot-start-marker
boot-end-marker
enable secret xxx
no aaa new-model
voice-card 0
dspfarm
no local-bypass
ip cef
--More-- !
no ip domain lookup
isdn switch-type basic-net3
--More-- !
interface FastEthernet0/0
ip address x.x.x.x 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface BRI1/0
no ip address
isdn point-to-point-setup
isdn layer1-emulate network
isdn incoming-voice voice
--More-- isdn bind-l3 ccm-manager service mgcp
interface BRI1/1
no ip address
shutdown
ip http server
no ip http secure-server
control-plane
voice-port 1/0/0
compand-type a-law
cptone GB
voice-port 1/0/1
--More-- !
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server x.x.x.x
ccm-manager config
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
--More-- !
line con 0
line aux 0
line vty 0 4
password Wellesb0urne
login
end
Please see the ISDN STATUS:
AUC_GATEWAY#
*Mar 2 02:12:55.357: ISDN BR1/0 Q921: User TX -> IDREQ ri=11550 ai=127[OK]
*Mar 2 02:12:57.356: ISDN BR1/0 Q921: User TX -> IDREQ ri=65279 ai=127
*Mar 2 02:12:59.359: ISDN BR1/0 Q921: User TX -> IDREQ ri=61168 ai=127
*Mar 2 02:13:01.948: ISDN BR1/0 Q921: User TX -> IDREQ ri=56817 ai=127
*Mar 2 02:13:03.947: ISDN BR1/0 Q921: User TX -> IDREQ ri=48386 ai=127
*Mar 2 02:13:05.950: ISDN BR1/0 Q921: User TX -> IDREQ ri=36131 ai=127
*Mar 2 02:13:11.964: ISDN BR1/0 Q921: User TX -> IDREQ ri=24404 ai=127
SDN BRI1/0 interface
dsl 0, interface ISDN Switchtype = basic-net3
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
Correct Answer by AJAZ NAWAZ about 9 years 6 months ago
here, try out this config;
interface BRI0/3/0
no ip address
isdn static-tei 0
interface BRI0/3/1
no ip address
isdn static-tei 0
Please also 'compand-type a-law' under voice port. Of course replace the interface numbers with your own.
hth,
Ajaz
Overall Rating: 5 (3 ratings)
paolo bevilacqua Fri, 11/09/2007 - 01:58
  • Hall of Fame,
    Founding Member
Any chance you need "isdn static-tei 0" in that location? Common for DID and multi-BRI provisioning.
In any case, enable "debug isdn q921" and "term mon" to see what's going on in there.
Correct Answer
AJAZ NAWAZ Fri, 11/09/2007 - 02:56
  • Silver, 250 points or more
interface BRI0/3/0
no ip address
isdn static-tei 0
interface BRI0/3/1
no ip address
isdn static-tei 0
hth,
Ajaz
