NATting a web server
Answered Question
Nov 9th, 2007
I'm having a silly problem. I have an Exchange server on my LAN, which has an Outlook Web Access page that needs to be seen from the Internet. Local address for it is http:/172.16.0.23/exchange.
On router I enter the simple
ip nat inside source static tcp 89.x.x.x (router internet address) 80 172.16.0.23 80 extendable
And it doesn't work..!
There are no ACLs currently in use, all routing & pings work fine, but users from Internet can't see the exchange site.
Correct Answer by Martin Parry about 9 years 8 months ago
You need to swap your addresses around. If you inside address is 172.16.0.23 then this should be the first address placed in the config line.
you are translating from the inside address to the outside address.
Overall Rating: 5 (1 ratings)
Correct Answer
Martin Parry Fri, 11/09/2007 - 03:20
  • Silver, 250 points or more
n_parshina Sun, 11/11/2007 - 22:03
Thanks!!
Should've payed more attention to examples!
