aaa new model (error)
Nov 9th, 2007
hi,
for ERROR , in my switch i used the cli AAA NEW MODEL.
Now when i try to enter , it tell me username and password.
I don't have any username configured.
what can i do without to reset the switch for to enter in enable mode?
thanks
FC
Overall Rating: 4 (1 ratings)
Edison Ortiz Fri, 11/09/2007 - 07:31
Yes, you got locked out. Resetting the switch is your only solution. Next time, before enabling 'aaa new-model' make sure to have a local username and password.
Note.- the switch won't lose all its configuration (reset = reboot on this case). The only configuration that will be lost, is the one made recently (before a copy run start, of course).
bvsnarayana03 Fri, 11/09/2007 - 07:47
Most people doesnt get it right the first time. So next time you are configuring aaa on any device, make sure you enable local authentication & set username & password.
Minimum aaa config to save u from getting locked while configuring aaa for tacacs:
aaa new-model
aaa authentication login local
username abc password xyz
Anytime u r locked while configuring, u can use the above username & password to gain access.
Please refer this doc for more details if ur interested:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/7.x/configuration/guide/authent.html#wp1221026
Happy Diwali.
ddemirchi Sat, 11/10/2007 - 09:33
aaa new-model
aaa authentication login localacc local enable
// localacc; you can set this to anything you like, but have to define in console 0 and vty x x too or leave it as it is
username username privilege 15 password yourpassword
line cons 0
login authentication localacc
line vty 0 4
*** may have to modify enable or secret passwod
