Problem in installing ACS trial version
Nov 9th, 2007
I am having problem in installing ACS 4.1 trial version. On invoking the progem after installation completion, I get the web page "CiscoSecure ACS Trial" opened.
Appreciate your advise, why I am getting this web page and how to fix it.
Overall Rating: 5 (2 ratings)
andrew.brazier@... Fri, 11/09/2007 - 06:24
You need to add the site (or localhost) to the trusted sites list in IE then when you open the link you will get the ACS welcome page. (Make sure you install the Java runtime as well).
