CSM Load Balancer Help
Hey,
Just a quick question....
Does anyone know a) if it's possible and b) how to have two servers off the CSM but instead of load-balancing between them make them a failover pair i.e. if server A goes down server B will take over - done using the same VIP?? It's needed because the application on the servers can't do load-balancing yet but can work in a failover way.
I'm reading the book trying to work it out but if someone has done this before that would be great!
Anthony
Jon Marshall Fri, 11/09/2007 - 07:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Anthony
You don't say which version of software you are running but one way to do this is to place each server into a different serverfarm and then use one of the serverfarms as the active serverfarm and the second serverfarm as the backup serverfarm.
Attached is a link to a configuration example for this.
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/csm/4.2.x/configuration/guide/cfgxpls.html#wp1008909
Jon
Hey Jon,
Thanks for the response. I'm using CSM 4.6(6) and have given what you suggested a go but have run into problems.
When I disconnect the primary server I see that go out of service but that also knocks out the VIP and it never fails over to the second server. Am I missing something? I've attached the relevant parts of the config and would be greatful for any advice.
serverfarm FARM1
nat server
nat client WEB
real 10.2.250.10
inservice
probe HTTP
serverfarm FARM2
nat server
nat client WEB
real 10.2.250.11
inservice
probe HTTP
vserver WEBTRAFFIC
virtual 10.2.250.100 tcp www
vlan 250
serverfarm FARM1 backup FARM2
persistent rebalance
inservice
Cheers mate.
Anthony
