BGP problem on old 7200non-VXR
Nov 9th, 2007
I have a small problem on an old 7200non-VXR:
I have two BGP sessions from R1 to R2 and R3. I advertise some networks but get no routes back (not enough RAM for a full table). So I have two default routes from R1 to R2 and to R3 (higher metric on the default route to R3). The problem is, if R2 dies, the default route still points to R2. I don't have access to R2 or R3 so getting a default route injected via BGP isn't possible. Route tracking is also not a possibility as route tracking isn't supported on 12.2 (which is the last release which runs on 7200nonVXR). So any other ideas?
Thank you,
Edison Ortiz Fri, 11/09/2007 - 09:01
I suggest trying this approach in a lab.
Create a route-map
route-map internet 10
set ip next-hop R2
set ip next-hop verify-availability
route-map internet 20
set ip next-hop R3
at the ingress interface
interface f0/0
ip policy route-map internet
Let us know how it works out.
martinkluge Sat, 11/10/2007 - 10:26
thank you for your answer. But I still have a question. If I understand the "set ip next-hop verify-availability" command correctly, it requires that CDP is enabled on R1, R2 and R3. Is this correct? The problem is, that R2 and R3 are non-cisco routers and do not support CDP.
Thank you,
