11-09-2007 05:55 AM - edited 03-03-2019 05:45 AM
Hi all,
I have a very weird problem with a 6506 connecting to a 3750 over single mode fibre.
The connection is single mode fibre using LX/LH Gbics. When i try to connect using the 6506 the connection shows as down/down. If i replace the 6506 with a 3560 - remove the g-bic and patch lead, and plug it into 3560 and it works.
So fibre is ok, gbic is ok, fibre patch leads are ok. I have tried various ports on the 6506 but all the same. I have one working link of similar setup working on the same card on the 6506.
Ports are all setup identically.
Any ideas guys??
11-09-2007 06:15 AM
One of the GBICs might be marginal. Have you tried replacing them?
I know you say they are all set up the same, but could you post the configs of all 4 ports concerned?
Kevin Dorrell
Luxembourg
11-09-2007 06:28 AM
I haven't tried replacing the gbics.
There is also a second link to a 6509, which doesn't connect either but connects to the 3560.
Here are the configs
6506:
Int G1/14
description To 3750
switchport
switchport trunk allowed vlan 27,39,43,60,78,304
switchport mode trunk
no ip address
Int G1/13
description to 6509
switchport
switchport trunk allowed vlan 15,27,28,39,145,302
no ip address
3750:
description To 6506 G1/14
6509:
set port name 1/2 Link to 6506
set trunk on dot1q 15,27-28,39,145,302
