Topology Services map links
Joe Clarke Fri, 11/09/2007 - 08:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The links should absolutely move with their connected objects. Make sure you are using the one supported version of Java on your client.
Joe Clarke Fri, 11/09/2007 - 10:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Try re-laying out the map to hierarchical, and see if the links collapse.
Joe Clarke Fri, 11/09/2007 - 10:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can certainly move objects. I can't reproduce the problem you're seeing. I re-layout my map, then move some objects around, and the links move accordingly. Note, the layout engine algorithm may not be doing what you want based on whre you're trying to move objects, but unfortunately, this cannot be changed.
juliocarossella Fri, 11/09/2007 - 17:01
hi:
Delete the link, move the devices, and finally Perform Data Collection.
By the way, are you using VLAN trunking (802.1q) between switches and routers?
I`ve an issue with trunk lines, because as soon as I configure trunking on the router`s FastEthernet interface (through subinterfaces), the lines vanish off.
That is to say that routers and switches connected vía trunk interfaces are showed without any line between them.
