CNR RPC error.
Nov 9th, 2007
Hi All,
I installed the CNR 5.5.12, and I created the two cluster name, but when I try to connect it, I am getting the "RPC host unknow" error.
Can you please tell how to solve this or how to configure the cluster in CNR?
Overall Rating: 5 (1 ratings)
David Stanford Fri, 11/09/2007 - 08:36
  • Cisco Employee,
This error message is caused if the cluster name is not the same name as the host machine that houses the cluster. Once the cluster name is the same as the machine name, the error will go away.
examples20001 Fri, 11/09/2007 - 19:00
Thank you very much.
When I tryed to add administrator, I am getting error message "Unable to give administrator 'administrator' access rights to cluster 'abcserver'".
How can I add administrator to the cluster?
examples20001 Mon, 11/12/2007 - 03:11
I tryed re-install the CNR, but again same error message is comming.
