VLAN, DMZ and Cisco 871-SEC-K9
Nov 9th, 2007
Recently I bought Cisco 871 Advanced Security router. In table on the product site http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheet0900aecd8028a976.html is info that the router with this IOS image gives support for two VLANs from which one is dedicated to DMZ. I was trying to build this DMZ with SDM but without any success. Also I tried to enter the VLAN to database manually via console but I got only
Vlan can not be added. Maximum number of 1 vlan(s) in the database.
Is there any way to add the second VLAN as it should be possible?
1 vote
wdrootz Thu, 11/15/2007 - 10:53
Under one SSID, only one VLAN can be configured. You need to go for 2 SSIDs.
Router(config)# interface dot11radio 0
Router(config-if)# ssid cisco
Router(config-if-ssid)# vlan 1
Router(config-if-ssid)# authentication open
Router(config-if)# ssid test
Router(config-if-ssid)# vlan 2
Router(config-if-ssid)# authentication network-eap eap_methods
w_zamiar_ Thu, 11/15/2007 - 12:18
Ok, I know it. But this isn't wireless router :) It's version without WiFi. But thanks for the message
