MGCP T38 - CUCM6
Nov 9th, 2007
  • Silver, 250 points or more
Has anyone gotten this to work successfully?
I am using RightFax with SR140. The call goes out the PSTN and connects to the far end fax, but cannot negotiate the proper RTP.
I have verified all codec, relay, etc. MGCP T38 is supposed to be supported with CUCM6.
Any ideas would be great.
Thank you,
Jon
gogasca Sun, 11/11/2007 - 00:03
  • Green, 3000 points or more
Hi Jon,
Yes...we do support T.38 and CCM 6.0
What is your current setup?
Sr140 -- H323 -- CCM -- MGCP ?
In 4.2(3) and 6.0 afaik when CCM downloads the config to the MGCP, it no longer includes the T.38 FAX inhibit command....which is a problem if you don't have a gateway IOS version that supports it:
12.4(7.12) / 12.4(7.14)T or later.
To be honest I have only tested in 4.2(3) but should be the same logic.
