How to config WRR to reserve min BW for incoming traffic frm specific ports
Nov 9th, 2007
On a Cat6513, I would like to mark all incoming traffic from two specific ports with different COS and then reserve min. 40% bandwidth for each port (2/1 and 2/2) on a trunk port (2/3).
E.g.
Port 2/1 - access port (COS 1) - reserve min. 40% bandwidth of 2/3
Port 2/2 - access port (COS 5) - reserve min. 40% bandwidth of 2/3
Port 2/3 - Trunk (dedicate link for above ports)
Is it possible if using wrr?
Here's my configuration:
set qos enable
set qos map 2q2t tx queue 2 2 cos 5,6,7
set qos map 2q2t tx queue 2 1 cos 1,2,3,4
set qos map 2q2t tx queue 1 1 cos 0
set qos txq-ratio 2q2t 10 90
set qos wrr 2q2t 100 255
set port qos 2/1 port-based
set port qos 2/1 cos 1
set port qos 2/2 port-based
set port qos 2/2 cos 5
However, I don't know how I can reserve min. 40% bandwidth for each port (2/1 and 2/2) if using 2q2t
Thanks in advance.
Rgds,
Ivan Cheng
