AP 1231 Configuration
Nov 9th, 2007
I always have this problem when I console to the AP1200 to start initial configuration. I see it boot up on the terminal, but when i press enter to get started, nothing comes up on th eterminal.
So I usually connect it to the network, allowing it to obtain a DHCP address and the access it with that IP address.
unfortunately this is not working now with a new AP I am setting up. It gets an IP address and I can ping it, but cannot telnet or web browse to that IP address to configure the AP.
Basically I cannot access the AP for configuration. Can someone help
john.preves Fri, 11/09/2007 - 22:24
what happens if you reset it to default?
I would be interested in seeing what the vty 0-4 and vty 5-15 settings are but since you can't get in it...
p.holley Wed, 11/14/2007 - 08:56
i have reset it to default several times by poering off the AP, holding down the button and then powering it back up and then releasing the mode button.
i am unable to access it via console and telnet so i dont know what the vty setting are
virenderjaglan Mon, 11/19/2007 - 06:06
HI,
for reset the ap press mode button for 20 second then supply the power to the ap.
after that u can use console for access the ap via hyper terminal.
thanx
