No ringback when calling a cellphone from CME
Nov 9th, 2007
I have CME running on a 3845 router with the latest CME code and correct IOS.
When a user dials out to a cell phone they do not hear any ringback but are able to connect to the cell phone and voice call proceeds fine. The VoIP user just never hears any ringback.
Is there a bug or something that Telco has to fix?
Seth
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Fri, 11/09/2007 - 15:06
Are you using PRI? If so please send output of "debug isdn q931" with "term mon". There are workaround commands, but I would like to see the call progress first.
srosenthal Mon, 11/12/2007 - 05:27
No, this site is using all BRI.
Here is the output from debug isdn q931. The first is for a call to cell phone and the second is a call to a land line.
2d16h: ISDN BR2/0/1 Q931: Applying typeplan for sw-type 0xC is 0x0 0x0, Calling
num 3025
2d16h: ISDN BR2/0/1 Q931: TX -> SETUP pd = 8 callref = 0x04
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Preferred, B1
Keypad Facility i = '18045551212'
Calling Party Number i = 0x0080, '3025'
Plan:Unknown, Type:Unknown
2d16h: ISDN BR2/0/1 Q931: RX <- CALL_PROC pd = 8 callref = 0x84
Channel ID i = 0x89
Exclusive, B1
Locking Shift to Codeset 5
Codeset 5 IE 0x2A i = 0x80880B, '18045551212', 0x8001098001148001148001
14
2d16h: ISDN BR2/0/1 Q931: RX <- INFORMATION pd = 8 callref = 0x84
Called Party Number i = 0x80, '18043477539'
Codeset 5 IE 0x2A i = 0x808300800114800114800114800114
2d16h: ISDN BR2/0/1 Q931: RX <- CONNECT pd = 8 callref = 0x84
Progress Ind i = 0x8482 - Destination address is non-ISDN
Nov 12 08:24:52 EST: %ISDN-6-CONNECT: Interface BRI2/0/1:1 is now connected to 1
8043477539 N/A
2d16h: ISDN BR2/0/1 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x04
new_lexington_res#
Nov 12 08:24:58 EST: %ISDN-6-CONNECT: Interface BRI2/0/1:1 is now connected to 1
8043477539 N/A
Nov 12 08:25:07 EST: %ISDN-6-DISCONNECT: Interface BRI2/0/1:1 disconnected from
18045551212 , call lasted 14 seconds
2d16h: ISDN BR2/0/1 Q931: TX -> DISCONNECT pd = 8 callref = 0x04
Cause i = 0x8090 - Normal call clearing
2d16h: ISDN BR2/0/1 Q931: RX <- RELEASE pd = 8 callref = 0x84
2d16h: ISDN BR2/0/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x04
new_lexington_res#
num 3025
2d16h: ISDN BR2/0/1 Q931: TX -> SETUP pd = 8 callref = 0x03
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
Keypad Facility i = '18045551211'
2d16h: ISDN BR2/0/1 Q931: RX <- CALL_PROC pd = 8 callref = 0x83
Channel ID i = 0x89
Exclusive, B1
Codeset 5 IE 0x2A i = 0x80880B, '18045551211', 0x8001098001148001148001
14
2d16h: ISDN BR2/0/1 Q931: RX <- ALERTING pd = 8 callref = 0x83
Progress Ind i = 0x8288 - In-band info or appropriate now available
Signal i = 0x01 - Ring back tone on
2d16h: ISDN BR2/0/1 Q931: RX <- CONNECT pd = 8 callref = 0x83
Signal i = 0x3F - Tones off
Nov 12 08:23:38 EST: %ISDN-6-CONNECT: Interface BRI2/0/1:1 is now connected to 1
8045551211 N/A
2d16h: ISDN BR2/0/1 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x03
Nov 12 08:23:44 EST: %ISDN-6-CONNECT: Interface BRI2/0/1:1 is now connected to 1
8045551211 N/A
Nov 12 08:23:51 EST: %ISDN-6-DISCONNECT: Interface BRI2/0/1:1 disconnected from
18043597070 , call lasted 12 seconds
2d16h: ISDN BR2/0/1 Q931: TX -> DISCONNECT pd = 8 callref = 0x03
2d16h: ISDN BR2/0/1 Q931: RX <- RELEASE pd = 8 callref = 0x83
2d16h: ISDN BR2/0/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x03
srosenthal Mon, 11/12/2007 - 10:35
I was already given that document by a co-worker and tried those steps with no success.
Seth
srosenthal Mon, 11/12/2007 - 11:00
dial-peer voice 145 pots
corlist outgoing call-domestic
description dial peer for PSTN LongDistance
preference 1
destination-pattern 91[2-9]..[2-9]......
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 2/0/1
forward-digits 11
Paolo Bevilacqua Mon, 11/12/2007 - 11:39
per document you should be sending PI 3 in setup, this is not happening. Which exact IOS is this
Do you have "voice rtp send-recv" in global config ?
Can you try "tone ringback alert-no-pi" please ?
srosenthal Mon, 11/12/2007 - 12:00
The IOS is c3845-advipservicesk9-mz.124-11.XW1.bin
I did not have the "voice rtp send-recv" in global config but I added it with no luck.
Here is the dial-peer now.
tone ringback alert-no-PI
preference 1
direct-inward-dial
port 2/0/1
forward-digits 11
Paolo Bevilacqua Mon, 11/12/2007 - 12:54
XW1 has been deferred, can you try latest XW4 or XJ4. I'm not positive that it would solve, but it's worth a try.
xiayunduan Sun, 11/18/2007 - 21:31
i have a 3845,running ios 12.4.12b
with fxo connecting to pbx
and no ringback tone too!
