Rate Lmitnig a VLAN interface
Nov 9th, 2007
I have just installed a L2 MPLS network using 7604 routers at the hub sites and 3845 routers at my edge. I would like to configure rate limiting on my devices.
On the 3845 I have implimented a Service-Policy on on my Ethernet Sub interface and this is owrking perfectly.
On the 7604 I use VLAN interfaces and the interface does not support shaping in the same manner.
Here is the config on my 3845
policy-map Max-Bandwidth
description Rate Limit for WAN Link
class class-default
shape average 24000000
bandwidth 20480
encapsulation dot1Q 904
ip address 10.2.252.10 255.255.255.252
ip tcp adjust-mss 1300
ip ospf cost 400
crypto map ToDC1
service-policy output Max-Bandwidth
On my 7604 this is the message I get when I try to apply the service-policy output command:
agdc01rtr01(config-if)#service-policy output Max-Bandwidth
shape average command is not supported in output direction for this interface
Configuration failed on:
Vlan504
What alternate methods are available to perform this peak bandwidth limiting on a VLAN interface?
