2821 T1 Config
Nov 9th, 2007
I have a 2821 with a VWIC2-MFT-T1 connected to a T1 slot on and IAD running Voice for VoIP system and the same card is carrying data through the T1. How can I setup ATM on the VWIC to match the ATM settings on the IAD?
allan.thomas Fri, 11/09/2007 - 15:23
In order to setup or configure the VWIC, you will require an ATM-AIM module. Ensure that you have the appropriate AIM depending on your requirements. Refer to the following link for supported AIMs.
http://www.cisco.com/en/US/products/hw/modules/ps2641/products_data_sheet09186a0080088753.html
Under the appropriate controller you specifiy mode atm aim 0 as shown below.
controller T1 0/1/0
mode atm aim 0
This will then enable you to configure the appropriate ATM interface configuration as in the following example:-
interface ATM0/1/0
description ???????/
bandwidth 1500
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
scrambling-payload
no atm ilmi-keepalive
interface ATM0/1/0.1 point-to-point
ip unnumbered Loopback0
no ip redirects
no ip unreachables
no ip proxy-arp
pvc ?/??
vbr-nrt 1500 1500 1
oam-pvc manage
oam retry 5 5 10
encapsulation aal5snap
Allan.
HTH.
Pls rate this post if you find it helpful.
