11-09-2007 12:58 PM - edited 03-15-2019 07:09 AM
Hi Guys,
CCME 4.1
voice-port 0/1/0
description FXS
dial-peer voice 401 pots
destination-pattern 7677
port 0/1/0
I want to monitor the number 7677 on the addon 7914. Is this possbile?
Thank you!
Solved! Go to Solution.
11-10-2007 01:47 AM
Actually you have to configure all things as per "FXS SCCP feature mode" document. I suggest you use a looback interface as "endpoint address" for this.
Thanks for the nice rating and good luck!
Hope this helps, please rate pots if it does!
11-09-2007 01:34 PM
Hi Ken,
yes there is a method, configure the FXS port as an ephone:
http://cisco.com/en/US/products/ps6706/products_feature_guide09186a00806cab75.html
you will have all the ephone feature on the analog phone, and the ability of monitoring it. This is oly supported on ISR's however.
11-09-2007 03:06 PM
Thank you! I take it I would have to configure like...
voice-port 0/1/0
description FXS
port 0/1/0
ephone-dn 5
number 7677
label 7677
description Analog Polycom
name Boardroom
ephone 1
mac-address 0000.0000.0001
username "reception" password 123456
type 7961 addon 1 7914
button 7m5
11-10-2007 01:47 AM
11-11-2007 05:56 PM
Hi Paolo,
Sorry I don't get it. The only thing it says is enabled the "stcapp call-control mode feature"
Can you kindly provide some config example? Thank you!
11-11-2007 06:07 PM
Rightly, you couldn't see the config examples from that document that is about the optional "feature mode" only.
Please refer to:
http://cisco.com/en/US/products/ps6441/products_feature_guide09186a0080483a76.html
for the "basic" config of sccp mode for fxs ports. I should have provided that link before, sorry for the confusion.
11-12-2007 09:44 AM
Thank you Paolo! I'll give it a go tomorrow as I am off today, and update "Resolved my issue" as needed.
11-15-2007 02:49 PM
Hi Paolo,
All is well! Thank you for all you help!!!
To add to this... I had to do a "sh ephone anl" to get the mac address. I let the CCME auto assign the MAC. There was no way I was going to tried to do the conversion.
