cisco srnd vs autoqos
Nov 9th, 2007
why are they different, autoqos sets queue0-limit 65 15 15, while srnd recommend 5 25 40, however with this config the priority queue stays at the default of 15 and that leaves 15% unaccounted for.
also in new version of code queue bandwidth is done in weight, not percentages, and autoqos assigns 20 100 200 vs srnd which says use bandwidth 5 25 70. Any suggestions or just play with it until you arent dropping traffic?
bwilmoth Thu, 11/15/2007 - 14:11
  • Silver, 250 points or more
AutoQoS VoIP automatically configures the best-practice QoS configurations (based on previous Cisco Enterprise QoS SRNDs) for VoIP on Cisco Catalyst switches and IOS routers. By entering one global and/or one interface command (depending on the platform), the AutoQoS VoIP macro then would expand these commands into the recommended VoIP QoS configurations (complete with all the calculated parameters and settings) for the platform and interface on which the Auto-QoS VoIP macro
is applied.
