How do I access a network camera from internet via 501
Nov 9th, 2007
Please understand that I am nowhere near being a network guru and I'm even farther away from being a PIX guru.
I have a 501 PIX between my home network and the outside internet. The PIX is connected to a cable modem and pretty much keeps the same DHCP IP address as assigned by the ISP. I have an AXIS 207 IP camera connected to my home network on IP 192.168.1.11. For the sake of illustration say the address assigned by my cable ISP is 123.123.123.1.
What I need to do is to access the camera from the internet. To do that I suppose I need to add some instructions to the PIX configuration but I don't know where to start...I have never even thought about communicating with devices on my home network through the internet. Can someone please provide some pointers or better yet the commands I need to add. The next question is how do I access the camera assuming the PIX is all set up. I don't think I use the camera's address and I don't know how the ISP address would get to a specific device such as the camera - maybe appending a port number or whatever to the IP address I type when trying to access the camera from the internet?
The way the camera works on the internal network is you type in it's IP address in a browser window and the camera opens up a web page just like any url and the video is streamed to a window in the web page.
I hope I've provided enough info to understand what I'm trying to do and I would be most appreciative for any help.
thanks
The PIX can be configured to translate ports destined to a single global IP address to your internal camera.
You can use port redirection (static PAT) to accomplish this.
Example
Address from ISP: 123.123.123.1
Camera IP Address: 192.168.1.11
PIX commands are shown below.
static (inside,outside) tcp 123.123.123.1 80 192.168.1.11 80 netmask 255.255.255.255
!--- Now that the port redirection is defined, you need
!--- to allow inbound access via an access list.
access-list inbound permit tcp any host 123.123.123.1 eq 80
access-group inbound in interface outside
!--- Finally, then you need to do PAT on the static address.
nat (inside) 1 0.0.0.0
global (outside) 1 123.123.123.1
Please rate if this helps, also I would make sure you camera has a user name + password on.
Regards MJ
cisco501pix Sat, 11/10/2007 - 07:39
Thanks for the answer...I will install the changes and report back with the results
cisco501pix Sat, 11/10/2007 - 15:49
I tried installing the commands as provided but am running into issues. Here are the error messages:
pixfirewall(config)# nat (inside) 1 0.0.0.0
ERROR: Duplicate NAT entry
ERROR: fail to insert nat entry
pixfirewall(config)# global (outside) 1 xxx.xxx.114.55
ERROR: xxx.xxx.114.55-xxx.xxx.114.55 overlaps with outside interface address
And here is a copy of my current configuration (including the code prior to entering the changes and the successful changes). Any Idea what needs to be done to fix things?
thanks
Building configuration...
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname pixfirewall
domain-name ciscopix.com
clock timezone CST -6
clock summer-time CDT recurring
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 100 permit icmp any any echo-reply
access-list 100 permit icmp any any time-exceeded
access-list 100 permit icmp any any unreachable
access-list inbound permit tcp any host xxx.xxx.114.55 eq www
pager lines 24
logging timestamp
logging trap informational
logging host inside 192.168.1.3
icmp deny any echo outside
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.1.3 255.255.255.255 inside
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp xxx.xxx.114.55 www 192.168.1.11 www netmask 255.255.255.255 0 0
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
aaa authentication http console LOCAL
aaa authentication telnet console LOCAL
aaa authentication serial console LOCAL
aaa authentication enable console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 15
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.6-192.168.1.10 inside
dhcpd dns 207.69.188.171 207.69.188.172
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
username administrator password xxx privilege 15
terminal width 80
Cryptochecksum:xxx
: end
[OK]
