no hostname exists
Nov 9th, 2007
Using VPN 4.6.04.043 client - we are now seeing some "Error 5" no hostname exists -
The IP address or the hostname is stripped out along with the group and group password.
It is happening on Windows XP machines. I thought it was a Microsoft patch - any thoughts??
thult Tue, 11/13/2007 - 01:50
This normaly happens after you get a BSOD (blue screen) on the clients after connecting the VPN-tunnel.
I have not found any solution to this but newer versions of the client may work better.
I use 4.8.01.0300.
