Inter-Cluster Trunk
Nov 10th, 2007
i have two cluster and i am doing (Non-Gatekeeper Controlled) ICT. but it's not working.
i do setting like :
Product:Inter-Cluster Trunk (Non-Gatekeeper Controlled)
Device Name:my sever name
Tunneled Protocol:none
Inbound Calls
Significant Digits: All
Outbound Calls
Calling Party Selection:originator
Remote Cisco Unified CallManager Information
Server 1 IP Address/Host Name:my other cluster ip add
but i can't call one cluster to other cluster...???
Overall Rating: 5 (1 ratings)
Zin.Karzazi Sat, 11/10/2007 - 02:57
First you need to set up a route pattern to your remote site. Let s say your DNs are 7xxx and your remote site is using 6xxx.
set up a route pattern 6xxx and select the trunk Route List in it.
1- Include the Partition of your Route pattern (6xxx) in the CSS of your phones.
2- See if there is any pre dot or anything related in your Route pattern
3- Ensure that the route list on your RP is correct (ie Trunk Route List)
4- on your remote trunk-> Inbound call -> CSS
check if this css include the Partition of your phones.
if all this doesnt help. use Dialed Number Analyzer (https://ip/dna) select trunk and see what the results are. Activate Traces on both callmanager (SDI, SDL). Use a sniffer on your phone and see if he is sending packets to your remote CCM.
Zin Elabidine Karzazi
nagabhushanamj@... Mon, 11/12/2007 - 01:29
I have one doublt on ICT.
In my network I'm going to create one ICT between CCM4.x cluster & CCM6.x cluster. Is it work or not. since i have doubt that ICT will work between same version of CCM cluster. Please correct me..
kumaran.samikkannu Mon, 11/12/2007 - 06:23
Hi Naga
I have tested the ICT between CM4 and CM5 and between CM4 and CM6, it should work without any issues
