ddemirchi Sat, 11/10/2007 - 10:13
Could provide more information?
such as;
- PC --> Switch --> fiber --> Switch --> PC?
- Type of fiber and the distance, ie; MM, SM
- MM fiber w/SX GBIC 50/62.5 micron, type of glass is used in the fiber is about 800 feet 1GB and SM fiber up to 10K promising 1 GB with LX, LH GBIC 1 GB.
- Are you ether channeling?
If you have 65xx series switch, it has build in OTDR for physicial test and fiber DB lost..etc.
The simple way is;
setup linux box with virtual ram drive and run FTP on ether side of the network and monitor your speed
you might want to check fluke equipments; http://www.flukenetworks.com/fnet/en-us/
Good luck
