Disable the xauth in IOS router for EZVPN client
Nov 10th, 2007
I am trying to diable the xauth option and make the authentication by default not the interactive. I have tried using the username option, still its in the xauth interactive mode.Please can anyone help me out in this.
Overall Rating: 5 (2 ratings)
ajagadee Sat, 11/10/2007 - 11:04
  • Cisco Employee,
If possible, Can you post the current configuration from the router. If not, make sure that your configuration looks like the below:
crypto ipsec client ezvpn EZVPNCLIENT
connect auto
group TEST key TEST123
mode network-extension
peer 1.1.1.1
username cisco password cisco
xauth userid mode local
Let me know if it helps.
Arul
mkmzaman Mon, 11/12/2007 - 00:51
thanks for your reply.
I am using the same configuration for my device. i have given the mode as local and defined the username and password.
regards,
muneer
kcoming Mon, 11/12/2007 - 09:44
If the ezvpn server doesn't allow password storage on client, you won't be able to set this to xauth userid mode local.
On a 3000 head end, this is set on the hardware client tab for the group. For IOS/PIX head end, I don't know how to set it.
mkmzaman Mon, 11/12/2007 - 20:55
Thanks for your help.
I have enabled Password-storage command at Headend device, it started working.
ajagadee Tue, 11/13/2007 - 07:53
  • Cisco Employee,
Great! Thanks for the update!
Arul
xzjleo2005 Wed, 05/26/2010 - 18:07
Hi, which IOS verion comes with this 'local' option, my router only has   http-intercept and  interactive. it's c2800nm-advipservicesk9-mz.124-15.T7.bin
Thanks, Leo
