"ip routing" not available on CAT 6500?
Nov 10th, 2007
I was trying to issue a global command "ip routing" to enable inter-VLAN routing on a Cisco 6504 running IOS. But "ip routing" does not seem to be a valid command. Please advise the reason and alternatives.
#show ver
IOS (tm) s3223_rp Software (s3223_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF8, RELEASE SOFTWARE (fc2)
6504#show mod
Mod Ports Card Type Model Serial No.
1 9 Supervisor Engine 32 8GE (Active) WS-SUP32-GE-3B SAL1035ZRWM
3 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-TX SAL1052CDV6
Mod MAC addresses Hw Fw Sw Status
1 0017.94c1.58f0 to 0017.94c1.58fb 4.5 12.2(18r)SX2 12.2(18)SXF8 Ok
3 001a.a2b2.c930 to 001a.a2b2.c95f 1.5 8.4(1) 8.5(0.46)RFW Ok
Mod Sub-Module Model Serial Hw Status
1 Policy Feature Card 3 WS-F6K-PFC3B SAL1034ZHWU 2.3 Ok
1 Cat6k MSFC 2A daughterboard WS-F6K-MSFC2A SAL1035ZM8B 3.1 Ok
Overall Rating: 0 (1 ratings)
ohassairi Sat, 11/10/2007 - 10:52
  • Silver, 250 points or more
what error message do you get?
jackawang Sat, 11/10/2007 - 10:54
It says the command "ip routing" does not exist. I am in EXEC mode.
6504#config t
Enter configuration commands, one per line. End with CNTL/Z.
6504(config)#ip routing
% Invalid input detected at '^' marker.
andrew.butterworth Sat, 11/10/2007 - 11:14
  • Gold, 750 points or more
I noticed this the other day when I was setting up a Sup720 in the lab. The issue (if you can call it an issue) is you can't disable IP routing on the 6500 running Native IOS so it is always enabled and can't be disabled. Type 'show ip route' and there will be a routing table (assuming you have at least one interface with an IP address).
Andy
ddemirchi Sat, 11/10/2007 - 10:57
turn on Cisco's Express Forwarding (CEF)
- ip cef
then try ip routing?
glen.grant Sat, 11/10/2007 - 11:09
  • Purple, 4500 points or more
It may be you can't turn it off so there is no command to turn it on . never really tied to turn it off on the new 720's though we do it all the time on our 4500's.
glen.grant Sat, 11/10/2007 - 11:12
jackawang Sat, 11/10/2007 - 11:25
1. Unless I missed something, I am sure it is running IOS not CatOS.
6504#show ver
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Fri 02-Mar-07 21:02 by tinhuang
Image text-base: 0x40101040, data-base: 0x42D30000
2. "ip cef" is enabled. It did not solve the issue.
3. Assuming you cannot turn off "ip routing" on, it makes sense because it does show routing tables.
6504#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 63.xx.xx.209 to network 0.0.0.0
192.168.197.0/26 is subnetted, 1 subnets
S 192.168.197.64 [1/0] via 172.16.99.100
172.16.0.0/24 is subnetted, 5 subnets
C 172.16.10.0 is directly connected, Vlan10
C 172.16.4.0 is directly connected, Vlan4
C 172.16.5.0 is directly connected, Vlan5
C 172.16.2.0 is directly connected, Vlan2
C 172.16.99.0 is directly connected, Vlan999
63.0.0.0/28 is subnetted, 1 subnets
C 63.xx.xx.208 is directly connected, Vlan3
S* 0.0.0.0/0 [1/0] via 63.85.41.209
Now the question is how I can enable inter-VLAN routing? I am not able to ping a host on different VLAN. Please advise.
6504#show ip interface bri
Vlan1 unassigned YES NVRAM administratively down down
Vlan2 172.16.2.1 YES NVRAM up up
Vlan3 63.xx.xx.219 YES NVRAM up up
Vlan4 172.16.4.1 YES NVRAM up up
Vlan5 172.16.5.1 YES NVRAM up up
Vlan10 172.16.10.1 YES NVRAM up up
Vlan999 172.16.99.1 YES NVRAM up up
GigabitEthernet1/1 unassigned YES unset up up
GigabitEthernet1/2 unassigned YES unset up up
Harold Ritter Sat, 11/10/2007 - 11:28
  • Cisco Employee,
If you want to ping from one vlan to the other, make sure that the default gateway on the hosts on these vlans is set to the IP address of their respective vlan interface.
Hope this helps,
jackawang Sat, 11/10/2007 - 11:32
All host's default gateways are set to the IP address of their respective VLAN interface already. In my case, 172.16.xx.1.
andrew.butterworth Sat, 11/10/2007 - 11:36
Sounds a bit bizarre.... Check the ARP cache on your PC for the gateway, make sure it is the 6500's MAC address for that VLAN. Try some traceroutes from your PC. It's not just XP's firewall is it?
Andy
ddemirchi Sat, 11/10/2007 - 11:56
Where are the hosts?
- different building or they are directly connection to 6504?
- check trunking
- check vlan pruning
- check vtp domain on the other switches.
check access switch;
- switch mode access
- switch acc vlan x
DHCP Scope configured?
- are you able to get IP address on host? or u r assigning static? check subnet mask, de.gateway...
ddemirchi Sat, 11/10/2007 - 11:32
If you are running hybrid; L2; sup1,2,320,720
When you telnet;
Cisco Systems Console
Username: username
Password:
c6504-sw> (enable)
c6504-sw> (enable)session 15 or 16...etc.
User Access Verification
Username: username
Password:
cmsfc-rtr-1>en
Password:
cmsfc-rtr-1#
ddemirchi Sat, 11/10/2007 - 11:41
are you running any type of routing protocol?
an example;
router eigrp 1
network 10.x.x.x
network x.x.x.x
no auto-summary
!ip classless
no ip forward-protocol nd
no ip forward-protocol udp tftp
no ip forward-protocol udp nameserver
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
ip route 0.0.0.0 0.0.0.0 x.x.x.x ; if you have pix or depand on your network topology
ip route x.x.x.x 255.255.0.0 x.x.x.x ; if you have pix or depand on your network topology
no ip http server ; to run off your http svr
or you can route it STATIC;
by ip route IP; x.x.x. Sub.Mask; x.x.x.x to destination...
Can you send us "show run" on supx and MSFC?
and if it is possible your network topology?
Harold Ritter Sat, 11/10/2007 - 11:43
  • Cisco Employee,
The two vlans are directly connected to the 6500. There is no need for a routing protocol in this scenario.
jackawang Sat, 11/10/2007 - 12:00
To summarize my test, I have a host on VLAN99 and I try to ping the GW(6500) and other hosts on diffrent VLAN.
From host 172.16.99.100:
Ping 172.16.99.1 -- OK (implies it can reach the gateway 6500)
Ping 172.16.99.131 -- OK (impies it can reach the other host on same VLAN)
ping 172.16.10.1 -- OK (implies it can reach the gateway 6500)
ping 172.16.10.131 -- timeout (implies it cannot reach the other host on different VLAN)
From the 6500, I can ping every hosts on every VLANs. My understanding from the test results is that the inter-VLAN routing is not working. Please kindly advise.
Harold Ritter Sat, 11/10/2007 - 12:08
  • Cisco Employee,
There is nothing additional you need to do to enable inter-vlan routing. I would double-check the default gateway setting on the second workstation and as mentioned by another poster, I would check if XP FWs are enabled and preventing icmp from other subnets.
Jon Marshall Sat, 11/10/2007 - 12:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Can you post
1) Output of ipconfig from both PC's
2) The interface vlan configuration of vlan99 and the other vlan.
3) Ouput of "sh ip route" on 6500
4) Can you also confirm that both ports that connect to the 6500 for the PC's are in their respective vlans.
Jon
glen.grant Sat, 11/10/2007 - 12:32
Ip routing is working if you can ping the router interface 10.1 from .99 subnet . Check the default gateway on the device that won't ping and also that the subnet mask matches the router for that subnet .
jackawang Sat, 11/10/2007 - 12:42
Okay, here comes the tricky part.
My laptop(Host A) has an single NIC on VLAN99:
IP: 172.16.99.100
Mask: 255.255.255.0
GW: 172.16.99.1
HostB has multiple NICs on different VLANs:
NIC1: 172.16.10.22
NIC2: 172.16.2.22
NIC3: 172.16.3.22
HostB's default gateway is set to 172.16.10.1(VLAN10).
HostA and HostB can both reach it's default gateway. But HostA and B cannot ping each other. Please advise.
Jon Marshall Sat, 11/10/2007 - 12:44
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Can you post the output of the following command from a cmd prompt on Host B
netstat -nr
Jon
ddemirchi Sat, 11/10/2007 - 12:57
I seen this problem before....
Your current issue is with Windows NIC Bindings.
- control panel
- open network connection
- click on Advanced from tool-bar
- Select Advaned settings
- Move UP/Down NIC for the first or use for your network.
jackawang Sat, 11/10/2007 - 14:01
I had no default gateway set on HostB! Once the gw is set, everything worked like charm! Thanks to everyone and apologies for my careless.
This leads me to think of an interesting issue -- if "ip routing" is enabled by default and is unable to disable, what if I want to turn it off?
ohassairi Sat, 11/10/2007 - 20:37
if you want to remove inter-vlan routing remove interfaces vlan X
(config)# no interface vlan 10
in your switch or use access lists.
