Firewall rule help on Cisco 837?
Nov 10th, 2007
Hi, I have this config on my Cisco 837, is it secure from the "outside" world? I can't see any rules that block anyone accessing my network, can you? I want the inside to have full access to the outside world, but the outside to have no access into my network.
version 12.4
no service pad
service password-encryption
hostname ADSL
boot-start-marker
boot-end-marker
no logging buffered
enable password 7 ****
no aaa new-model
resource policy
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp pool client
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.100
dns-server 190.x.x.197 187.186.189.16
lease 0 2
no ip cef
username *** password ***
interface Ethernet0
ip address 192.168.2.100 255.255.255.0
no ip unreachables
ip nat inside
ip virtual-reassembly
hold-queue 100 out
interface Ethernet2
no ip address
shutdown
hold-queue 100 out
interface ATM0
no ip address
no ip unreachables
no ip mroute-cache
atm vc-per-vp 64
no atm ilmi-keepalive
dsl operating-mode auto
cdp enable
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
interface Dialer1
ip address negotiated
no ip unreachables
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname ***
ppp chap password ***
ppp pap sent-username *** password ***
ppp ipcp dns request
ppp ipcp wins request
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 102 interface Dialer1 overload
logging trap debugging
logging facility local4
logging source-interface Ethernet0
access-list 102 permit ip 192.168.2.0 0.0.0.255 any
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
transport output telnet
line aux 0
line vty 0 4
exec-timeout 5 0
login local
transport input telnet ssh
transport output all
scheduler max-task-time 5000
end
whiteford Sun, 11/11/2007 - 02:03
Thanks, what exactly is my current config doing to block external traffic?
Do I need add a deny inbound to all traffic to stock hackers?
thotsaphon Sun, 11/11/2007 - 02:22
Hi Andy
I'm not 100% sure your IOS being supported firewall functions.If you can then I would recommend you to do *firewall* on it. As per your requirement you can do "Inspect" traffics you want allow from inside to outside and then you can do "deny all" from outside to inside. That's why I recommend "Inspect functions" because it's state-full.
Please check this link out!
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_configuration_example09186a008009445f.shtml
Hopes this helps
Thot
whiteford Sun, 11/11/2007 - 02:56
Thanks, the 837 has a full firewall feature.
Are the inspect rules from inside to outside like allow rules then? If so I take I would allow http, https, dns?
eg
ip inspect name outbound tcp
ip inspect name outbound udp
ip inspect name outbound ftp
ip inspect name outbound http
ip inspect name outbound icmp
ip access-list extended inbound_acl
deny ip any any
interface Dialer1
ip access-group inbound_acl in
interface Ethernet0
ip inspect outbound in
Richard Burts Mon, 11/12/2007 - 20:16
Andy
In a different thread we have had a discussion about firewall rules and about ip inspect. Has that sufficiently cleared things up or do you still have questions?
Rick
whiteford Mon, 11/12/2007 - 22:44
Its all good on this post, I have added the log file on the other one you asked for.
Richard Burts Tue, 11/13/2007 - 03:44
Andy
I seem to have lost track of a thread. Can you point me to the one you added the log file for?
Rick
whiteford Tue, 11/13/2007 - 04:00
Damn, my last post isn't there with the log, I'll try and get it and post.
