Natting Problems
Nov 10th, 2007
hi, i have configured the router to dial PPPoE connection and do natting & routing:
ip nat inside source route-map Connection_1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
route-map Connection_1 permit 10
match ip address 1
match interface Dialer1
anyway, everything works fine, except for few strange issues,
such as, when i tun P2P client, the speed become very slow behind the router, if i connect the P2P client directly to the internet, it's very fast.
id like to know why, what causes that natting is not functioning well when i use P2P, while almost all other applications run smoothly?
tekha Sun, 11/11/2007 - 05:52
  • Bronze, 100 points or more
Well, what does your access-list 1 look like?
What router model are you using ?
How much load is there on the processor when using P2P? ("sh proc cpu his")
And do you have firewall features (CBAC/inspect) enable on the router?
xbaha54321 Sun, 11/11/2007 - 12:49
hi, thanks for reply, here is the ansowers:
access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
Router Cisco 3845
the load is not that much, i am currently the only user using it for testing.
cpu < 1% utilization, and memory is almost free.
no firewalls enabled at all at the router..
