Cisco 2600 Logging function.
Nov 10th, 2007
I wanna logging some event about user logon/off, configuration change activity.
Now, I can sent logs to my syslog server but only i can see is "@SYS-5-CONFIG_I: configured from console by console".
I wanna logging what change it does, too.(EX. ip address changed or access list changed or who login ... )
All logging level were set "7-debug", Pls tell me, what setting should I to do?
jbayuka Thu, 11/15/2007 - 15:11
Syslog information - If the router is set up to send logs to a syslog server, you may be able to obtain information on what happened. For details, refer to the How to Configure Cisco Devices for Syslog section of Resource Manager Essentials and Syslog Analysis: How-To.
Refer to the document Hardware Troubleshooting for the Cisco 2600 Series Router for more information
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a0080094ae0.shtml
