Using WAN DHCP, 4/5 pings ARP
Answered Question
I am using a cable modem connected to fa0/1 using DHCP on a 2621. I read that first ping is lost due to an ARP lookup. It seems to do a lookup on every address, including public IPs. It is causing every web page request to be delayed.
Config:
version 12.3
service timestamps debug uptime
service timestamps log uptime
hostname Router2621
boot-start-marker
boot-end-marker
enable password 7
no aaa new-model
ip subnet-zero
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp pool 1
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip audit po max-events 100
username Pat password 7
interface FastEthernet0/0
description Local Network
bandwidth 1200
ip nat inside
duplex auto
speed 100
interface FastEthernet0/1
description connected to Internet
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat log translations syslog
ip nat inside source list 7 interface FastEthernet0/1 overload
ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
access-list 7 permit 192.168.1.0 0.0.0.255
access-list 100 permit udp any any eq bootpc
snmp-server community private RW
snmp-server enable traps tty
line con 0
exec-timeout 0 0
password 7
login
line aux 0
line vty 0 4
password 7
login
end
Correct Answer by paolo bevilacqua about 9 years 6 months ago
you should replace "FastEthernet0/1" or gateway address in 0.0.0.0 default route with "dhcp". If "command error", then need to upgrade IOS.
In recent code, you don't need to configure the default route at all.
In any case, you also don't need "default-router" that is only for when routing is disabled.
Moreover you don't even need:
as the roueter will never assign his own address via dhcp.
Correct Answer by Jon Marshall about 9 years 6 months ago
It's your default-route that is doing it
If your default-route was changed to be
ip route 0.0.0.0 0.0.0.0 "next-hop IP"
then your router would not need to arp for all destinations just the next-hop IP address. But because you have told it the default-route is out of the fa0/1 interface your router will arp out for all destinations.
Do you know what the next hop should be ?. If so change your default-route entry as in example above.
Jon
Overall Rating: 5 (4 ratings)
Correct Answer
Jon Marshall Sun, 11/11/2007 - 01:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
Jon Marshall Sun, 11/11/2007 - 12:00
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Glad it helped.
Default-gateway should not change as long as ISP is leasing out of the same subnet range but it is worth talking to them to find out.
Jon
Correct Answer
paolo bevilacqua Sun, 11/11/2007 - 14:14
  • Hall of Fame,
    Founding Member
paolo bevilacqua Sun, 11/11/2007 - 14:58
  • Hall of Fame,
    Founding Member
woops I didn't looked the excluded address correctly. that included router address and is all good as well.
Glad to know it helped, please remember to rate posts using the scrollbox below!
