PIX 6.2 to 7.1 conversion
Answered Question
Nov 11th, 2007
Hi all, well I'm new to the PIX world so if anyone can help, here goes.
Is there a tool that converts PIX 6.x ios configs to 7.1. I'm going from a PIX 506 to a 525.
Correct Answer by srue about 9 years 5 months ago
if you're using conduits, you can convert them to ACL's using the OCC tool available here:
http://www.cisco.com/cgi-bin/tablebuild.pl/pix
other than that, there's no tool for what you need. most of the commmands will be the same though. It will be easier if you first upgrade the 506 to 6.3(5) though.
Overall Rating: 5 (1 ratings)
Correct Answer
srue Sun, 11/11/2007 - 02:36
  • Blue, 1500 points or more
