What does the "ip inspect" command do?
Nov 11th, 2007
I have a Cisco 837 router for home use on my ADSL line, there are no firewall rules inplace as far as my knowledge goes. What does the "ip inspect" rule do and do I need to add it to the ethernet inteface inbound?
version 12.4
no service pad
service password-encryption
hostname ADSL
boot-start-marker
boot-end-marker
no logging buffered
enable password 7 ****
no aaa new-model
resource policy
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp pool client
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.100
dns-server 190.217.138.197 187.186.189.16
lease 0 2
no ip cef
username *** password ***
interface Ethernet0
ip address 192.168.2.100 255.255.255.0
no ip unreachables
ip nat inside
ip virtual-reassembly
hold-queue 100 out
interface Ethernet2
no ip address
shutdown
hold-queue 100 out
interface ATM0
no ip address
no ip unreachables
no ip mroute-cache
atm vc-per-vp 64
no atm ilmi-keepalive
dsl operating-mode auto
cdp enable
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
interface Dialer1
ip address negotiated
no ip unreachables
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname ***
ppp chap password ***
ppp pap sent-username *** password ***
ppp ipcp dns request
ppp ipcp wins request
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 102 interface Dialer1 overload
logging trap debugging
logging facility local4
logging source-interface Ethernet0
access-list 102 permit ip 192.168.2.0 0.0.0.255 any
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
transport output telnet
line aux 0
line vty 0 4
exec-timeout 5 0
login local
transport input telnet ssh
transport output all
scheduler max-task-time 5000
end
whiteford Sun, 11/11/2007 - 11:13
Thanks John,
1.) I've seen example applying it to the ethernet 0 inbound, any ideas why?
2.) So does it just inspect, what exactly is that?
3.) Also from the config above, I don't seem to have any firewall rules (unless I'm missing something). I want to be able to go outbound to the internet with no blocking (http, https, ftp, telnet, work VPN etc), but block the usual inbound traffic, should I have an access list?
Richard Burts Mon, 11/12/2007 - 14:49
Andy
Has our discussion about ip inspect in the WAN forum clarified your understanding of this or do you still have questions?
Rick
