11-11-2007 09:21 AM - edited 03-03-2019 05:47 AM
I recently followed the password recovery for a catalyst 4506 switch. Everything went ok but when I enter enable mode I don't get the # at the end. When I try to run configure terminal I get the error listed below. I need to know why the # is missing but I am in enable mode and why I can't use configure terminal.
Console> en
Enter Password:
Console> (enable) configure terminal
This function provided by set commands. Use 'set help' for more info
Console> (enable)
Solved! Go to Solution.
11-11-2007 01:54 PM
Royal is correct that is a catos prompt so you need to know catos and all the "set" commands in order to configure . This has to be one of the early 4506's if it is a 4506 and not a 4006 as most 4506's are IOS based . The early ones did come with a sup II which was catos based. The other answer to your question that may be in your head is no you cannot change it to IOS without a new supervisor card. If you do a "show mod" you will see it is a SupII module and what versions software , it will be like 7.6.17 instead of like IOS where it a 12.2.25EWA10 or whatever.
11-11-2007 10:37 AM
The device you are trying to log in has catalyst operating system (CATOS).
On these devices there is no # sign for the enable prompt but instead is shown as above and is an expected behavior :-). These devices use SET and Clear commands for configuration
Narayan
11-11-2007 01:54 PM
11-12-2007 04:42 AM
I ran "show mod" got
1000BaseX Supervisor WS-X4013
the "show config" states
version 8.4(4)GLX
I have 4 modules installed with 48 ports each. I want to use the span command to forward all the traffic from those ports to one. Can I do this with one command span command to accomplish this task?
set span 2/1-48, 3/1-48, 4/1-48, 5/1-47 4/48
Another question can I upgrade the current version of CATos version 8.4(4)GLX to version 8.4(11)GLX. If so does it make a difference?
Any ideas where I can find a PDF using CATos?
I need to use tftp to copy the file to a computer on the LAN.
11-12-2007 07:21 AM
that supervisor is indeed a SupII module . You can upgrade to the latest 8.4.X code if you want , it will give no added functionality mostly code fixes . I'm not sure why you want to span that many ports to one . Can you do it ? Sure but you run the high probability that you will vastly overun the port you are spanning to unless its a gig port then you may get away with it , all you have to do is think about it , you running all the data from 192 ports down to a single 100 or 1 gig port . It really depends on how much traffic your users generate.
Catos configs.
11-12-2007 08:10 AM
Can you tell me on a software that I can use to monitor the bandwidth of the switch and each port? I basically want to zero in on the machines that are producing high volumes of traffic. Thanks for the information on span didn't realize the consequences of spanning all the ports into one port and yes it was a lot of information even with ethereal.
