isdn callback not working
Nov 11th, 2007
I'm trying to configure my router C1841 to allow the callback to isdn remote user.
The callback perfectly work with my analog remote users.
The router did not initiate callback to the remote isdn caller.
fredlem07 Thu, 11/15/2007 - 04:09
I'm using a dialer profile and I already tried to configure the dialer interface using the commands as described in the "Configure ISDN Caller ID Callback for Dialer Profiles "
section of the document you provided to me but still the same issue.
When I remove the callback from the dialer caller string, the connection can be established by the client isdn modem (whitout callback at this time)
Thanks a lot.
fredlem07 Tue, 12/11/2007 - 00:27
Here is the configuration of my ISDN dialer interface :
interface Dialer10
ip unnumbered FastEthernet0/0
ip access-group sdm_dialer10_in in
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer remote-name xxxxxx
dialer idle-timeout 600
dialer enable-timeout 2
dialer string 027429815
dialer caller 027429815 callback
dialer-group 10
peer default ip address dhcp-pool xxx-Users
compress stac software
no cdp enable
ppp callback accept
ppp authentication ms-chap ms-chap-v2 callin
end
Could you please let me know what I'm missing ?
The debug show the following :
Dec 11 09:26:16.610: ISDN BR0/0/0 Q921: User RX <- UI sapi=0 tei=127
Dec 11 09:26:16.610: ISDN BR0/0/0 Q931: SETUP pd = 8 callref = 0x11
Sending Complete
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Calling Party Number i = 0x2183, '27429815'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '27338878'
Dec 11 09:26:16.614: ISDN BR0/0/0 **ERROR**: host_incoming_call: DIALER ERROR 0x1: b channel 0, call id 0x48
Dec 11 09:26:16.618: ISDN BR0/0/0 Q921: L2_EstablishDataLink: sending SABME
Dec 11 09:26:16.618: ISDN BR0/0/0 Q921: User TX -> SABMEp sapi=0 tei=125
Dec 11 09:26:16.634: ISDN BR0/0/0 Q921: User RX <- UAf sapi=0 tei=125
Dec 11 09:26:16.634: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/0, TEI 125 changed to up
Dec 11 09:26:16.634: ISDN BR0/0/0 Q921: User TX -> INFO sapi=0 tei=125, ns=0 nr=0
Dec 11 09:26:16.634: ISDN BR0/0/0 Q931: RELEASE_COMP pd = 8 callref = 0x91
Cause i = 0x8095 - Call rejected
Dec 11 09:26:16.654: ISDN BR0/0/0 Q921: User RX <- RR sapi=0 tei=125 nr=1
Dec 11 09:26:26.653: ISDN BR0/0/0 Q921: User TX -> RRp sapi=0 tei=125 nr=0
Dec 11 09:26:26.665: ISDN BR0/0/0 Q921: User RX <- RRf sapi=0 tei=125 nr=1
Dec 11 09:26:31.769: ISDN BR0/0/0 Q921: User RX <- DISCp sapi=0 tei=125
Dec 11 09:26:31.769: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 125 changed to down
Thanks a lot for help
Wilson Samuel Thu, 12/20/2007 - 07:17
It says that it has encountered Err:
Over here we are yet not very sure why the call has been rejected.
Could you please post the outputs from:
1. Debug Dialer
2. debug ISDN q931
3. debug ppp authentication
Then we can be certain what exactly is causing the rejected calls.
HTH,
Please rate all helpful posts.
Kind Regards,
Wilson Samuel
