Joe Clarke Sun, 11/11/2007 - 16:27
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I thought these modules were basically 3750s on a stick, so they should be supported. What's the sysObjectID of this switch module?
Joe Clarke Mon, 11/12/2007 - 08:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, there is currently no support for this module using that sysObjectID. Does this module offer the command:
snmp-server sysobjectid type stack-oid
If so, using that command will allow RME to manage the device as if it were a 3750-STACK.
azeindler Tue, 11/13/2007 - 07:45
Thanks for your mail.
We could configure the above command but in the running configuration we don't see the command appear.
We try to delete the device from DCR and reimport it, but the result is the same:
- Device Unknown and no chance to get the configuration in RME.
Any other ideas
Joe Clarke Tue, 11/13/2007 - 07:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If that command is not valid, then RME will not be able to support this device until a device package update appears for it. I know of no ETA for ESW device support in RME.
azeindler Tue, 11/13/2007 - 08:25
It means that I have to open a TAC case or ask for a feature request?
Joe Clarke Tue, 11/13/2007 - 08:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You should open a TAC service request to find out if the support for this module is on the roadmap.
azeindler Tue, 11/13/2007 - 13:47
Thanks a lot for support. I'll open a TAC case
Kind regards
