CUCM 6.X - 7945, 65, 75
Nov 11th, 2007
Anyone know when they plan on incorporating these phones into Call Manager for device type selection? Is there any articles on recommended selections on how these will work with CUCM 6.X now? I am most concerned about the 65 as it's colors opposed to the 61?
rob.huffman Sun, 11/11/2007 - 15:24
Hi Robert,
These models have been added to CCM 6.x and other versions with the following Device Pack installs. So you should be good to go :)
Cisco Unified IP Phone 7975G, 7965G and 7945G Release Notes for Firmware Release 8.3(2) (SCCP and SIP)
The SCCP version of firmware release 8.3(2) is compatible with Cisco Unified Communications Manager releases 6.0, 5.1, 4.3, 4.2 and 4.1
4.1(3)SR5
ciscocm.4-1-DevPack-55
4.2(3)SR2
ciscocm.4-2-3-DevPack-30
4.3(1)
ciscocm.4-3-1-DevPack-12
5.1(1)b
cmterm-devicepack5.1.1.3125-1
5.1(2)
cmterm-devicepack5.1.2.3101-3
6.0(1)
cmterm-devicepack6.0.1.1102-1
From this doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7975g/firmware/8_3_2/english/release/notes/75832.html
Hope this helps!
Rob
rraver Tue, 11/13/2007 - 14:46
I downloaded and installed this on a 6.0.1.2000-3 that came in a business edition bundle. I still don't have the option to select the model 65 or 75. Do I just use the 71 and 61 model with that load?
Rob
Chris Deren Tue, 11/13/2007 - 15:33
It is there with 6.0.1.2000-4. You cannot use the other phone types.
HTH,
Chris
rraver Thu, 11/15/2007 - 19:16
I have upgraded to that version and they still don't show up in the device list, any advice?
rraver Thu, 11/15/2007 - 19:28
The phone has the message "Registration Rejected: Error DBConfig"
rraver Thu, 11/15/2007 - 19:33
On another note I turned on auto-registration it actually loaded the phone as a 7975 with the appropriate load. Although I still can't find anywhre in the UI within the device add page and the default load information page that makes mention of the 5 seris.
