1310 Bridge
Nov 11th, 2007
Whitch type of encryption is the best for a bridge. (2pcs. of 1310)
WPA2-PSK? or is there a better solution?
Best regards
dennischolmes Mon, 11/12/2007 - 12:26
"It depends" on what you consider important. WPA2/PSK will suffice in most cases. Especially if you use directional antennae to connect the 2 bridges as this will limit the amount of physical exposure of your bridge to other parties.
