URL access on inside
Nov 11th, 2007
Hello Community,
I have a ASA5505, simple configuration inside, outside. On the inside I have a DNS, IIS, SQL server. One fixed outside IP from ISP. I can access my websites from the outside but I can't from the inside. I can ping the IIS server on the inside but I can't view my site http://www.alt74.net on the inside. Can you point me in the right direction what needs to be configured. ASA or DNS server? Before the ASA5505 I had a LinksSys small biz firewall and URL access worked inside and outside. Many thanks in advance
Overall Rating: 4.5 (2 ratings)
altziebler Sun, 11/11/2007 - 19:14
This is great! Haven't found this during my own research. Thanks so much! Jurgen
JORGE RODRIGUEZ Sun, 11/11/2007 - 20:19
  • Green, 3000 points or more
You should be all set once you go over the link, if you need help in configuring it let us know.
Rate any helpful post
Rgds
Jorge
altziebler Tue, 11/13/2007 - 08:48
i tried to follow the settings. But now I see in the Syslog Messages: Deny IP spoof from (192.168.1.112) to 70.164.46.246 on interface inside
mmh?
altziebler Tue, 11/13/2007 - 12:45
Many thanks for your help!
Result of the command: "show running-config"
: Saved
ASA Version 8.0(3)
hostname ciscoasa
domain-name default.domain.invalid
enable password ry.XY4BFXaMwWBtg encrypted
no names
name 192.168.1.20 SERVER1 description DNS
name 192.168.1.35 SERVER2 description IIS
name 192.168.1.40 SERVER3 description SQL
name 192.168.1.10 AppleAirport description WiFi
name 192.168.1.30 SERVER2-2 description Ethernet 100
interface Vlan1
description ALT74 LAN
nameif inside
security-level 100
interface Vlan2
description COX
nameif outside
security-level 0
ip address XX.XXX.XX.XXX 255.255.255.224
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
same-security-traffic permit intra-interface
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list inside_access_in extended permit ip any any
access-list outside_access_in extended permit tcp any host 70.164.46.246 eq www
access-list outside_access_in extended permit icmp any any
access-list outside_access_in extended permit tcp any host 70.164.46.246 eq ftp
access-list outside_access_in extended permit tcp any host 70.164.46.246 eq 1433
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
nat-control
global (inside) 1 interface
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 dns
static (inside,outside) tcp interface www 192.168.1.35 www netmask 255.255.255.255
static (inside,outside) tcp interface 1433 192.168.1.40 1433 netmask 255.255.255.255
static (inside,outside) tcp interface ftp 192.168.1.20 ftp netmask 255.255.255.255
static (inside,inside) XX.XXX.XX.XXX 192.168.1.1 netmask 255.255.255.255 dns
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 XX.XXX.XX.XXX 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.100-192.168.1.130 inside
dhcpd dns 192.168.1.20 192.168.1.22 interface inside
dhcpd domain alt74.local interface inside
dhcpd enable inside
dhcpd dns 68.100.16.30 68.10.16.30 interface outside
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
JORGE RODRIGUEZ Tue, 11/13/2007 - 13:46
Config is fine, firts time I've seen this message in dns doctoring. I believe by adding bellow statement in your config it will allow traffic flow between interfaces without acl.
try adding:
same-security-traffic permit inter-interface
altziebler Tue, 11/13/2007 - 13:51
Is there anything special I need to do in the DNS server (Win Server 2003). I had a LinkSys small biz firewall before and it worked fine inside, outside.
altziebler Sun, 11/18/2007 - 13:34
Hello Commmunity,
I am still struggeling with accessing my URL on the inside. URL access from outside works great but from the inside ASA5505 tells me IP spoof, access denied. Any help/tip would be great. Thanks, Jurgen
