CME 4.2
Paolo Bevilacqua Mon, 11/12/2007 - 10:00
  • Hall of Fame,
    Founding Member
first of all, can you configure ext. mobility ? Latest I heard has not been delivered yet. Then COR should follow the mobile DN.
Paolo Bevilacqua Mon, 11/12/2007 - 16:08
  • Hall of Fame,
    Founding Member
Not really. Would COR work for you? probably not as it is not overridable.
I'm not sure if you can use PIN login with ext. mobility, with that you can also block certain calls. Latest resort is steering digits, to prepend.
