RAS config
Nov 11th, 2007
Hi!
I want to configure my 3725 router to become dialin access server using analog modem. Your help will be much appreciated.
Tnx!
guruprasadr Tue, 11/20/2007 - 05:05
HI, [Pls RATE if HELPS]
Here is the Sample Configuration of RAS Router:
service nagle
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service linenumber
hostname <--->
logging buffered 10000 debugging
aaa new-model
aaa authentication login default tacacs+ line
aaa authentication ppp default if-needed tacacs+
aaa authorization network default tacacs+ if-authenticated
aaa accounting exec default start-stop tacacs+
aaa accounting network default start-stop tacacs+
aaa accounting connection default start-stop tacacs+
aaa accounting system default start-stop tacacs+
enable secret 5 <---->
enable password 7 <---->
ip subnet-zero
ip rcmd rcp-enable
ip rcmd rsh-enable
ip rcmd remote-host xyz nobody
ip rcmd remote-host xyz ovadmin enable
ip domain-list <---->
ip name-server <------>
ip accounting-threshold 4096
vpdn enable
vpdn search-order domain dnis
async-bootp dns-server
clock timezone MET 1
interface Loopback0
description *L0* ***********
ip address
no ip directed-broadcast
interface Ethernet0
description *connected to LAN*
ip address
ip access-group # in
ip access-group # out
no ip redirects
ip route-cache same-interface
ip route-cache policy
no ip mroute-cache
interface Group-Async1
description **-----**
ip unnumbered Loopback0
encapsulation ppp
ip tcp header-compression passive
no ip mroute-cache
async dynamic address
async mode interactive
peer default ip address pool ras-pool
no cdp enable
ppp authentication pap chap callin
group-range 1 8
ip local pool ras-pool
ip classless
ip route 0.0.0.0 0.0.0.0
logging trap debugging
logging
>> ACL Configuration<<
tacacs-server host key test
tacacs-server attempts 2
tacacs-server timeout 10
snmp-server community
>>SNMP Configuration
line con 0
password 7
transport input none
line 1 4
location <---->
autoselect during-login
autoselect ppp
modem InOut
modem autoconfigure type usr_courier
rotary 1
transport preferred none
transport input all
stopbits 1
speed 1200
flowcontrol hardware
line 5 7
location <--->
autoselect ppp
modem InOut
rotary 1
transport input all
stopbits 1
speed 57600
line 8
location <----->
autoselect ppp
modem InOut
rotary 1
transport input all
stopbits 1
speed 115200
line aux 0
password 7
transport input all
line vty 0 4
password 7
ntp
>>NTP Configuration
end
HOPE THIS HELPS.
PLS RATE IF HELPS
Best Regards,
Guru Prasad R
