Cisco 851 change default SSH port
kamikatze
I have this Cisco 851, nothing fancy:
c851-xxxxxx(config-line)#do sh run | b line vty 0 4
line vty 0 4
exec-timeout 7 0
privilege level 15
login local
transport preferred ssh
transport input telnet ssh
I'm trying to change ssh port to something >1024 with rotary groups:
c851-xxxxx(config-line)#line vty 0 4
c851-xxxxx(config-line)#rotary 1
X121 address and queued type can not be configured on the same rotary group 1
c851-xxxxx(config-line)#rotary 2
X121 address and queued type can not be configured on the same rotary group 2
c851-xxxxx(config-line)#rotary 3
X121 address and queued type can not be configured on the same rotary group 3
Works on a 2811 with advipservices:
ip ssh port 4343 rotary 1
line vty 5
exec-timeout 5 0
rotary 1
transport input ssh
My 851 is running advsecurityk9.
Is there any way around this? Thanks.
htarra
Level 4
Level 4
Yeah, you should be able to do this. Basic idea is to convert the 871 console into an aux with "modem enable", then use the "ssh terminal-line access" feature to enable "reverse SSH" into the 2800 console.
The config would go something like this:
username fred pass 0 FLINTSTONE
crypto key generate rsa
ip ssh port 2000 rotary 1
ip ssh break-string
line con 0
modem enable
line aux 0
no exec
transport input ssh
rotary 1
login
then, to do the "reverse ssh" out the aux 0:
$ ssh -l fred -p 2000 ip.addr.of.871
Should work on paper but as soon as i reach
c851-bacau(config-line)#line aux 0
c851-bacau(config-line)#rotary 1
I get the dreaded X121 error.
Maybe the advsecurity IOS is a no go for this.
