how can i use IDSM-2 in inline mode for more than two VLANs?
Nov 12th, 2007
can i use the IDSM-2 in inline mode to be ips to more than two VLANS
like this or it isn't
intrusion-detection module 5 data port 1 access-vlan 10,20,30,40,50
intrusion-detection module 5 data port 1 access-vlan 100,200
thank u all for your help
Overall Rating: 3 (2 ratings)
marcabal Mon, 11/12/2007 - 06:32
The IDSM-2 ports need to be configured as trunk ports with multiple vlans rather than as access ports.
And instead of creating an inline interface pair by pairing Gig0/7 with Gig0/8 within the IDSM-2 configuration, you would create inline vlan pairs.
With an inline vlan pair you pair 2 vlans on the same interface.
You can have up to 255 inline vlan pairs on each interface (assumining you keep the total traffic from all of the pairs within the IDSM-2s performance limit of around 500Mbps)
How to create inline vlan pairs:
The other aspect you need to be aware of is that not all IOS versions will support configuring the IDSM-2 data ports as trunk ports for inline vlan pairs.
Your best bet is to use 12.2(18)SXF4 or a later version on the 12.2(18)SXF train.
The 12.2(33)SR train does not currently support the trunk feature for the IDSM-2.
