11-12-2007 03:42 AM - edited 03-03-2019 07:30 PM
I have configured OSPF in my network into 2 areas (backbone & area 1).
Now i have somes problems with it.
1. I verify OSPF on the R1
R1#sh ip route x.x.y.1
Routing entry for x.x.y.1/32
Known via "ospf 1", distance 110, metric 2, type intra area
Last update from x.x.y.129 on GigabitEthernet1/48, 00:10:52 ago
Routing Descriptor Blocks:
* x.x.y.129, from x.x.y.1, 00:10:52 ago, via GigabitEthernet1/48
Route metric is 2, traffic share count is 1
And the time 00:10:52 ago is the same on the others routers (ALL ROUTERS R2,R3,R4 ..)
and for any subnets int the network OSPF (X.X.X.X/Y)
and then after a few minutes
* x.x.y.129, from x.x.y.1, 00:00:12 ago, via GigabitEthernet1/48
And the time 00:00:12 ago is the same on the others routers (ALL ROUTERS R2,R3,R4 ..)
and for any subnets int the network OSPF (a.b.c.d/e)
Sometimse i found that the period is 10 minutes, 15 minutes and
it's a variable value.
Please tell me why and how to fix it.
Thanks so much
11-12-2007 04:12 AM
I am a bit confiused about your architecture. Are these routes to loopback interfaces ... it certianly looks like it because they are /32. Is the x.x.y.129 the same x and y in every case? Is you central router the ABR - I presume so because you have only one outlying area? And does the 'x' and 'y' in x.x.y.1 correspond to the 'x' and 'y' in x.x.y.129? If so, what are the masks?
Are the adjacencies flapping?
Perhaps you could post a show ip ospf neighbor and show ip ospf database from the central router's point of view.
Kevin Dorrell
Luxembourg
11-12-2007 05:15 AM
Thanks for your answer.
In my question, i use /32 such as an example. However, the problem is the same for any prefix, any router.
Addition, Ip interconnect between two routers adjencencies is prefix /30. Thus 'x' and 'y' in x.x.y.1 is correspond to the 'x' and 'y' in x.x.y.129.
- sh ip ospf nei
FULL/DR or FULL/BBR for router adj
Thanks for your help
