Is support for RFC 2869 in Cisco Access Registrar 4.1?
Nov 12th, 2007
I need to use for accounting two attributes Acct-Output-Gigawords and Acct-Input-Gigawords. Are these attributes supported in Cisco Access Registrar 4.1? I found only these supported RFC's:
• 2865 RADIUS
• 2866 RADIUS Accounting
• 2867 RADIUS Accounting Modifications for Tunnel Protocol Support
• 2868 RADIUS Attributes for Tunnel Protocol Support
• 3576 Dynamic Authorization Extensions
• 3579 RADIUS Support for EAP (updates RFC 2869)
• 2618 RADIUS Authentication Client MIB
• 2619 RADIUS Authentication Server MIB
• 2620 RADIUS Accounting Client MIB
• 2621 RADIUS Accounting Server MIB
• 4186 Extensible Authentication Protocol Method for Global System for Mobile Communications (GSM) Subscriber Identity Modules (EAP-SIM)
Cisco Access Registrar supports the following drafts:
• Digest Authentication over RADIUS (draft-sterman-aaa-sip-00.txt)
Thank you
