The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally. New Here? Click here to learn more and get started.
Cisco Community is an active and collaborative place to learn more about our products and ask questions of peers and Cisco experts! Check out some of the most popular conversations happening right now!
I configured a Cisco Catalyst 2960 Switch. I set vlan1 as the ip address of the switch as well as interface 1 with 192.168.1.1 with a class C subnet. Strangely I am not able to access the GUI, ping the switch or Telnet directly. However, I am able to...
i cannot log in to the SNTC portal, i have the necessary roles that were applied last week (beyond the 24 hour period that is required for SNTC portal access), but each time i try to log in at services.cisco.com, I'm redirected back to the registrati...
Hi all I'm setting up a CISCO LAB to keep me busy in my retirement. My Current network consists of a TP-Link Deco mesh network which works well for my IOT, PCs and internet access. I just got hold of a Cisco 1941 router with a EHWIC D8SGP module. ...
Hi,on ISE 2.4 in the live logs pages the report that one got clicking on the repeat counter was very useful because the endpoints were sorted by repeat counters. So it was very easy to find the endpoints with high repeated counters.With ISE 3.2 the r...
I have just started using Secure Client Posture on my windows workstations. All but 2 work fine. The two are using the IP of the ISE instead of the FQDN. All systems have the same ISEPostureCFG.xml files on them. If I disable the network connectio...
https://cfnng.cisco.com/browse/switching/productsWhen trying to download features via the download button the excel file does not work. Any ideas how to report?
NOTE: I have done the same test setup with 4000 series routers, and routing works fine.I have successfully setup 3 SVI (Static Virtual Interface) tunnels with IPSEC between 2 9300X switches.- I can ping the tunnel IPs- I can ping each VLAN interface ...
Hallo All! What is the reason that when enabling Telemetry on C9300 Series Switches, only Application Name, Usage and Througput are shown? Switches configured with telemetry show only Application Visibility (Name and Throughput) in DNA center. Why is...
Já cursei o Conceitos Básicos de Redes e/ou CCNA1 e/ou CCNA2 em outra academia, posso participar do WRIT 2024 nas etapas seguintes? Sim. Pedimos anexar neste tópico o arquivo PDF, com o certificado do Skills for All ou Networking Academy do curso já ...
Has anyone tried adding multiple Algo 8182 SIP Strobe devices to their Cisco CUCM 12.5 PBX? I'd like the devices to activate on both "ring" and "in-use" events, but according to Algo that requires the "Subscribe/Notify" dialog event RFC 4235 on the P...
Hi I'm trying to extended a L2 segment using MPLS L2vpn over GRE. I am able to establish the tunnel and get ospf and mpls adjacency also the xconnect between the peer is up but my 2 test pc cant reach each other. This is my PE3 config.interface Gigab...
We have configured two Lightweight Access Points using a 3504 WLC. Both access points are connected to the WLC, and have been assigned IP addresses through DHCP from the WLC. Both also state they are providing the WLAN we created. Authentication for ...
