Router Hanging
Nov 12th, 2007
Hello all,
I have 2 router connected via 2 LL links on WIC-2T modueles. When I've the 2 LL connected at the same time it cause one of the routers to hang. Anyone ever came across a simular issue?
spremkumar Mon, 11/12/2007 - 21:24
  • Red, 2250 points or more
In which router model you are trying this ?
Did you try to login via console and check the cpu utilisation and also logs related to any of the process or related to the interface of the router.
regds
michaelnolan Tue, 11/13/2007 - 09:57
cisco 2610XM (MPC860P) processor (revision 0x301) with 126976K/4096K bytes of memory.
Version 12.3(15b)
When I connect a console to the router, console access hangs also. I can't ping the FastEthernet interface of the router from the LAN, even though I can see the interface is up when I look at the switch it's connected too.
Do I have a bad router?
