Will I get a new certicificate after recertification of CCNA/CCNP?
Nov 12th, 2007
I recertified CCNA and CCNP some weeks ago.
Because the certificate I got 3 years ago will age out next spring, do I get a new certificate with the current validation date?
If not is there any document which validates my CCNA/CCNP which I can use in a job application?
Best Regards,
Thorsten
Overall Rating: 2.7 (3 ratings)
keller.oliver Tue, 11/13/2007 - 01:57
Hi Thorsten,
I'm not sure about a paper version, but the CTS can always be used to publish your credentials.
Our HR department demands sending just that to them, they don't want any more paper ^^.
Later,
Oliver
thonghawkyen Wed, 11/14/2007 - 08:46
Hi Thorsten,
I hv seen someone reply to this question a few months back saying that there will be no paper certificate sent to the candidate.
By the way i hv one question. Did you hv to recertify CCNA and CCNP separately or you just need to recertify your CCNP and that will automatically recertify your CCNA. Pls advise.
Thnks.
regards
thong
jeff.hardee Wed, 11/14/2007 - 14:34
Thorsten,
If your certification had not yet expired and you took a test which automatically renewed the certification, you would not receive another certificate. However, you can print out or allow someone else to see your current certification status from the Certification Tracking System by clicking on "Publish Credentials". The link to CTS is: https://i7lp.integral7.com/durango/do/login?ownername=cisco&channel=cisc... . That's probably the best method to use, as it comes directly from Cisco and is current.
As for Thong's question, the CCNA will automatically be recertified with a passing score on any 642-xxx exam. See http://www.cisco.com/web/learning/le3/learning_recertification_training.html . So if one was a CCNA and was working towards the CCNP, each successfully passed exam in that track would recertify the CCNA.
--JeffThorsten,
If your certification had not yet expired and you took a test which automatically renewed the certification, you would not receive another certificate. However, you can print out or allow someone else to see your current certification status from the Certification Tracking System by clicking on "Publish Credentials". The link to CTS is: https://i7lp.integral7.com/durango/do/login?ownername=cisco&channel=cisco&basechannel=integral7 . That's probably the best method to use, as it comes directly from Cisco and is current.
As for Thong's question, the CCNA will automatically be recertified with a passing score on any 642-xxx exam. See http://www.cisco.com/web/learning/le3/learning_recertification_training.... . So if one was a CCNA and was working towards the CCNP, each successfully passed exam in that track would recertify the CCNA.
--Jeff
jeff.hardee Wed, 11/14/2007 - 14:56
I'm not sure why the earlier post keeps doubling on me, but at least it's understandable. ;)
--Jeff
thonghawkyen Thu, 11/15/2007 - 04:27
Hi Jeff,
Thnks for addressing my question. The certtification tracking tool shows that my CCNA has expired even though i recert my CCNP before it expires. I will contact the certification support to see what they say.
regards
thong
